jmbfestool
- Jan 9, 2009
Redfox said:That drill, does it have a centershaft, apart from the 35mm cutting?
I have a piece of tabletop which is a little bent between two opposite corners. Is there a good method I can straighten it with? (40mm zebrano)?
Cheers,
Jacques.
That cutter above? It has a small center point is da wa u mean?
work top then?
Well I had a cupped work top they where both about 1100 long. The first one I used my electric hand planner and took out most of the bow in the middle then had my planer set to 0.5 to get all them lines out I put in it with the planer then used a belt sander to get it all smooth again took a while had a straight edge I kept running across I got it very flat again it was still cupped under Neath but it didn't matter as no one can see that. The second one I decided to cut in half and get the workshop to send it through the thicknesser and then glued it back together on a joint you couldn't tell once sanded up.
Jmb
