jmbfestool
Rear stop attached for large stock
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
John2532 said:Thanks for putting the time into the drawings JMB. It looks like we are pretty much thinking alike. Not using the manufactured rule would add a bit to the costs, unfortunately buying the empire/johnson T-square is probably less expensive than the raw-stock, then there is the machining. Instead of the adjustment plates, how about some cylinders that attach to the bottom? They could be threaded or still use the magnets. Not as much surface area but much easier to machine.
I have to head out to work but will think about ways to combine all of the features.
John
Mark Enomoto said:One of the key design problems to solve with the guide rail system is that you always need a piece of stock the same thickness to support the rail if its narrower than the rail. Anybody think of some kind of leveler to get around this problem? This is the design challenge...
Problem: Cut a piece of lumber that is narrower than the rail w/o using a piece of lumber of similar thickness
Anybody think of this w/o going to the tablesaw?
RonWen said:I have thought about how I will add the function to the parallel guides that I made (not using lumber strips) but I don't have it modeled or added the the guides yet -- maybe in the next week or two. These pictures are just of the original parallel guides.
http://picasaweb.google.com/ronwenner/20100620#
Mark Enomoto said:and I forgot to say, excellent sketchUP models and the machining looks great!
