nickao
- Feb 24, 2008
I make what ever thickness they need by sanding off the back ply or adding more ply. I can even use fiberglass mesh and epoxy for the backer on the super thin floors.
The inlays go in prefinished floors 50% of the time and in those floors the installers do not sand the floor.
The shellac and wax is an actual floor finish and is complete, no sanding required. It is a very beautiful finish much better than varnish or polyurethane. I would never wax the inlay just to have it sanded over. The wax could mess up the floor finish on the main floor. If the wax gets on the sanding pad the other parts of the floor can get contaminated with wax as the rest of the floor is sanded. I rarely do any finishing at all anymore.
For a floor that requires sanding, the inlay is installed and sanded right over with the big floor sanders. I use only a shellac sealer coat when that is the case, no wax. The shellac sanding sealer(just a 1lb to 2lb cut of shellac) prevents blotching and helps fills the pores of the wood. It is the first step the floor finisher will do after sanding the entire floor before the finish coats anyway. The installer will usually use a sanding screen over the sealer coat and between finish coats, not sandpaper. The sealer also brings out the colors so the client can see what the inlay will look like after the finish is applied. The Inlays with no clear sealer look completely different then when the sealer is applied, especially if you are using woods like Padauk, etc.
Nickao
Nickao
