Tink
Now ive had mine for a week and a half, this is what i reckon.
3 minor annoyances.
1- the vac outlet is on the left hand side and it gets in the way of a right hander. But when sanding a top and holding the BS with the right hand, you hold the cord/hose in the left ??? So im assuming its ment to be there, so its good for that purpose.
2- its LOUD and screams like a banchee, but earmuffs fix that.
3- No plug in cord. There might be a legal reason for that im not sure.
Phew, now the bad points are out of the way.... the good points ;D
Sanding veneered board. Brilliant. With the sanding frame attached its
impossible to sand through even with a 60# belt. Sand your veneered top and lose concentration and start talking to someone with it stationary and still running even for 5 minutes and it wont sand through. Its child proof.
The weight was a concern for me, but now its a major bonus. At over 15 pound and with 1400watts, it realy is a rapid remover, but at the same time, engage the frame and you can dial in from 0.01mm increments upwards in sanding depth so easy, so controlling the amount you remove is again child proof.
Soft slow start is heaven ;D No more chance of taking off and ruining your work (or crashing off the bench if the switch is engaged)
The "perfect" curled finger grip/pull at the end of the handle makes it a joy to hold when sanding tops. Its a machine to use one handed because its so heavy and well ballanced it dose the work for you.
The small platten is dead flat. With the sanding frame engaged so no material could be sanded, i placed it cross grain on some pre-veneered board with an 80# then lowered the frame and left it for 30 seconds. The result was a near "perfect" sanded patch exactly the same size as the platern. This is the key to the machine. I just dose what a belt sander should do. Awesome.
The quality of the sanding frame is as usual second to none. It engages and disengages is seconds even when you are using it, and moves up and down with ridiculous ease with the turn of a tiny lovley lime green dial ;D The size of the frame is big, 390 x 235mm and has hundreds of thousands of tiny bristles attached to nylon inserts and simply glides over what is being sanded
By far the easiest belt changing i have come across. Even someone with arthritis could manage it in seconds its so easy and smooth.
And piece to resistance - When you have finished using it, you simply turn it upside down (i leave the feet on all the time as they dont get in the road) and plonk in on a bench as a cracker little linisher "complete" with an up-side down sanding frame for guaranteed flatness of what your sanding. And taking it off (frame) if needed takes 10 seconds.
What a wonderfull power tool this is. The Domino still rules in my workshop because of what it dose for speed of construction, but this has to be the new King of the Power tools. I just love it ;D Do what ever you can to get one. You wont be disapointed
