mino
Careful there, that is a Zobo bit. Sharp as knife, tough the same and cuts softwood like butter ...TomK_2 said:P.S. I sure would like to see someone drill a hole in 4th gear with that 35mm forstner bit! If I end up getting the drill I'll do it and post a video.
About the gearing, what you say is not possible.
There are 2 gear ratios in 4-speed gearbox like the one in the TPC:
1.5 and 4.7 (rounded as do not have the gearbox in hand)
1x1 => 520-ish (as 500)
1.5x1 => 770-ish (as 800)
1x4.7 => 2350
1.5x4.7 => 3600
The older PDC had a bit higher top and a bit lower bottom speed and it has the 3rd speed (for me) in the "weird" teritory where it was slower than most good 2-speed drills. Notice the increase in the 2nd gear ratio from 4.5 => 4.7, that was clearly not done to improve longevity or torque, it does the opposite on both, so must have come from customer/user demand.
PDC/DRC has it at 2.1 and 4.5 for a bigger range:
1x1 => 400
2.1x1 => 850
1x4.5 => 1850
2.1x4.5 => 3800
Also, it is good to note the higher "low" speeds for the TPC. Both 1st and 3rd gear. That would have "consumed" about 20% of the torque uplift the TPC got from the stronger motor.
ADD:
What the DRC/PDC ratios mean for me, is I almost never use the 3rd gear and rarely the 2nd gear.
For stuff that does not need torque, I keep it at 4th 95% of the time, and regulate the speed by the trigger as needed - it is sensitive enough for working across about 500-3800 rpm range.
For stuff that does need torque, I almost always go to 1st gear. Rarely 2nd. I have used 3rd maybe like 2 or 3 times. Granted, the gear selector does not help here, but I just did not feel I *wanted* that 1850 speed for any task as the trigger-controlled 4th is more convenient.
With the new ratios on the TPC, I could see myself using the 3rd gear more often. It has a speed high-enough for many tasks. I can also see using the 2nd gear more often. It has only 1.5x the speed of the 1st so will have aplenty of torque still, unlike on the PDC.
Whatever went through Festool engineers heads, the updated gear rations DO make sense to me. Effectively thy now have two "strong and slow" gears in the 1st and 2nd and two "weak and fast" in the 3rd and 4th. On the PDC this was more evenly spread out, leaving the 3rd (and partially 2nd) in "no man's land". At least for me.
To me it seems like PDC/DRC were more an "engineer's design" as far as the gearing - lower demands on gears, more evenly spread ratios.
On the other hand, the TPC/TDC seem more an "user's (or specifically cabinet maker's)" design - higher demands on gears, more power given up for higher low speeds at the cost of more task-focused available speeds.
Looking back at the gearing changes, I can now safely say the TPC is an upgrade on the PDC but it is NOT more powerful/stronger drill, despite the paper values. Sure it has about 50% stronger motor, but most of the power from the stronger motor is "consumed" on higher low speeds and on making the torque break less of a deal breaker.
Now I am sure I will not be getting the TPC - it would not be an upgrade /in capabilities/ over my DRC with which I am happy capability-wise. The funny part: I would welcome a torque break on my DRC. It has twisted my arm more than once ... [cool]
