I understand. Per the engineer's evaluation, my structure will support the work with the originally proposed materials (mud and cement board). In a follow up email the engineer told me that there would be an additional 1% deflection each year due to seasonal humidity changes. So that 10 or so years from now there may be sufficient additional deflection to cause tile cracking. I plan on being in this house long term and would like a bathroom that will last as long as my family stays here. It's this "additional seasonal deflection" that I'm concerned about.
I looked at what it would take to beef up the structure to lessen the deflection and sag for "additional surety, if desired" as the the engineer's letter states. I have utilities going through that area, and I'm kind of tired of doing drywall work. I don't want to cut my subfloor open to access from the top. It's a big hassle, and doesn't resolve the issue that led to this thread.
The tile contractor's proposed work eliminated the traditional pre slope bed that is supposed to go under the mud bed. Plumbers are now laying the vinyl membrane flat on the subfloor. The tile guys are laying the sloped mud bed down and then applying a waterproofing membrane to the sloped mud bed to prevent water intrusion into the bed. If that membrane fails, the shower pan will not work as the traditional design where water is "exchanged", as there is no pre slope to guide the water to the drain weep holes. The way around this issue is to use a bonded flange drain with a waterproofing membrane. But bonded flange drains are not allowed in this municipality for some reason.
If the tile guy wasn't going to put in the pre slope bed, I was going to. After making a test pre slope bed, I started to think about the weight of the materials and the effect on the structure.
Before I started this project, I wanted the newer foam products to be used instead of the traditional methods. The tile guy doesn't use the foam products, and he wasn't even going to do the traditional method as it was designed. I have a penalty heavy contract with him, so firing him isn't very feasible. I may look into canceling the contract anyhow (I learned a lesson about signing these one-sided penalty-heavy contracts. Education isn't always cheap).
After pricing out the foam stuff and comparing that with the cost and the remodeling hassle to beef up the structure slightly, I decided that the foam may be the least invasive means of giving me the "additional surety". And it's what I wanted originally anyhow. I asked the tile contractor to quote the use of these materials. His pricing communicated that he didn't want to use them. Or he thinks I'm his magical lottery ticket or something. I can install what I want for far less. And I will!
