Marhk said:How does one disable the 2 button thing? Has anyone done it?
That plus the vertical handle make this less desirable - wrist fatigue/injury.
Of course the cost is not really a factor! :'(
Dave Rudy said:If you go to the website that Eli posted and click on "Watch movie" you will see a demo by Gary Katz on the device (and other stabila products) for the trim carpenter.
honeydokreg said:Marhk said:How does one disable the 2 button thing? Has anyone done it?
put tape over it so it stays down, but you did not hear that from me, that is what I heard on the grapevine
Greg in Memphis said:I've had my Kapex for about 2 weeks now and absolutely love it.
I am not a contractor, but I can appreciate top quality tools that give professional results. By professional, I mean as if a person were doing these projects for their own house and actually care. Not just some jerk you throw money at and have to redo their cover-up work 5 or 6 years down the road. I do hire out contractors for some work, but I am very selective for this very reason. 95 percent of the time, if I want it fixed right and right now, I do it myself.
I don't have alot of room in my shop and the Kapex stores and moves very easily when not in use. This seems to be a theme that all Festool tools have in common. Keep up the good work guys.
Everything worked perfectly right out of the box.
I have had the slightest bit of tear-out on the very back edge on some of my cuts, but I have not been using a backing board or an auxiliary fence. I'm thinking that would help. Besides, these come out just fine if I rake past them with a pocket knife.
The only reason I mention this minor issue is because I own a TS-75 and am used to perfect cuts. With the exception of the TS-75, this saw cuts better than any other saw I have owned so far.
Going along with the subject of this post, there are two things that I can think of that would make this a better saw:
1) How about sending an 8 foot section of 36mm hose with the Kapex?
2) I really like the dual lasers, But they could be...GREEN. Easier to see in bright daylight, and it's GREEN.
Just my thoughts
Greg
Jerry Work said:Hi Marhk,
From my own experience and watching others use the Kapex I think the comfort in using the vertical handle is a function of work height relative to the height of the operator. I really like being able to use the Kapex either right or left handed without having to change anything. I also really like the two button activation as there are many times I find alignment easier if the motor/blade housing is lowered a bit so the laser lines show on my mark better. I don't want the blade spinning while that is going on. It also seems more natural to me to lower the housing while pulling it back to the front of the cut before spinning the blade. With the soft start feature the blade spins up smoothly and quickly. One always wants to use a sliding compound miter saw by pushing the spinning blade into the work piece against the fence, never by pulling the spinning blade from the rear to the front which tries to force the work piece away from the fence.
So, my answer to your question is don't do it. Keep both functions of the two button engagement in place just like they are. If hand/wrist fatigue is an issue, adjust the working height of the Kapex and I think you will find a sweet spot where it is most comfortable. Hope this helps.
Jerry
