DeformedTree
- May 19, 2018
So in a classic case of "you can find it when you aren't ready to buy, but once you are you can't find it" I'm having this with large triangles.
I'm talking about units like the TSO PTR-18. When looking for them before, I was finding ones that could be had in either metric or inch. But now, no luck. Woodpeckers had a sorta metric one (inch tool re-done with mm markings), but it was a On time tool. I like the TSO PTR, but they don't make them metric or inch, they make it dual, so that's no good.
I swear I found just metric ones before, but now no luck. Are there other manufactures of similar units out there that I'm just not finding right now?
The WP PSQ660-19 is another option, on the plus side you can use it on outside corners unlike the triangle, but I'm not so keen on the triple layer edge, which means you can't use it as a lay flat square. Also out of stock.
Anyone else make similar products?
