pettyconstruction
- Oct 17, 2010
I have a love / hate relationship with the hold down.TomK_2 said:Kapex, where have you been all of my life? This thing is a joy to use...
- Cuts are smooth and very accurate
- Very little blade deflection
- Adjustments are very easy with accessible controls
- Bevel gauge is HUGE
- I actually really like the handle that I thought I would hate. Much easier keep the blade from deflecting.
- Slide out wings are a nice bonus feature
- Dust collection is good. Much better than the DeWalt. I wish it were even better so I may try a 36mm hose. I did rig up a 50mm hose but it was difficult to tell if it made any difference and it would get caught on things so I went back to the 27mm.
- Lasers are usable - much better than a single laser. I find myself turning them off and just lining up on a tooth for critical cuts.
- When installing base I sometimes need to do compound miter/bevel cuts to meet the casing tight. With the DeWalt I would sometimes just not even bother with a 1/2 degree bevel because it was such a pain to set up. With the Kapex it no longer feels like a chore.
- I really like the soft start and brake. They are dialed in perfectly to keep the saw from jumping around.
- The hold down clamp is one I actually will use
It's not all perfect though.
- The miter adjustment is a bit of a pain at times because you can't lock out the detent bypass. My workaround is to use a spring clamp to hold the detent bypass which is just silly.
- The included miter gauge is a neat concept but in reality is fairly useless. Most base will be too tall to be cut standing up and the gauge doesn't work to set a bevel. It's far easier just to buy a $15 miter protractor.
- It should have an option for a shadow line
- It is too easy to miss the bevel stop at 0 degrees
- The steep price makes you think twice before buying. At what point would the price be too much to pay for a miter saw?
I was really hoping to hate this saw so that I could get my $$$ back but unfortunately the Kapex is here to stay.
When I bevel the saw, it’s in the way,when I put it on the workbench I want it.
I find I use it more as a stop block.
I’ll keep trying it.
I use a 35mm Bosch hose and the dust collection is good,have thought about a 50mm hose and may try that.
If you ever wonder if the D/C is working or not,unplug the vac and cut, it’s a big difference .
Charlie
