woodbutcherbower
SRSemenza said:BTW, is the shadow line easier to see in sunlight or does it disappear if the sun is at a bad angle?
No light-based guidance device is going to work as well in bright ambient light as it does in low light, Seth (as you'll be well aware as an experienced woodworker) - so being perfectly honest, there’s probably not that much to choose between the two. But the SL is definitely more visible in bright light if you bend down and get a little closer to it. My last job before the current one was this hot-tub deck. Bright sunshine for a coupla days building the support legs and base framework. All accurate and tight with SL. But this is the UK - so it then rained constantly until the job was finished. Plastic bag over the saw’s motor, forever cleaning off wet sawdust sludge before it dries to wood-coloured concrete, and another few days making me glad I bought the Sys-Powerhub.
Kevin
