Brice,
I agree, that normally the 1/2 mm won't make any difference at all, in this case because I forgot and drilled the holes before I glued on the edging, the offset ended up being nearly 1.5mm and wasn't sure at first if that would cause a problem. After looking at the Blum hinges, it looks like there's enough adjustment that it still won't be a problem, but I still wanted to figure out, if possible, if there was something I was doing wrong, or if I just need to remember to adjust the stops by 1/2 mm next time I use them.
Fred
Fred
