- Nov 14, 2013
DanielOB said:ksp55 battery saw is not 36V, but 18V. It use one OR two 18 V battery...
As does the Festool TSC55. From the Festool UK website:
"Flexible dual battery concept: can be operated with two 18-volt battery packs (36V) for maximum power or one 18-volt battery pack for low weight"
Edit - Translated and cleaned up with the help of Google Translate from the german announcement of the TSC55 says this:
Variable dual battery concept
The double battery system enables use of all 15V and 18V lithium-ion battery packs from Festool. The system makes the use of one or two batteries possible - in any combination: two 18V, one 18V and one 15V, or two 15V - depending on the wishes and needs of the artisan. If maximum power is the goal, it can be achieved with two 18 volt battery packs, for a power of 36V. Where lighter weight is desired, the use of only one Battery Pack (either 18V or 15V) is possible.
