Al,
I recently did a crown molding project in an office reception area where they wanted the old banker look as I call it. Really dark cherry everything. This incidentally was the office of one of the clients that I used the lye solution for their home. Anyway, with the only moldings available in time and within budget being white pine, I starting looking for a stain.
I selected the same exact stain that you did - Valspar Cabernet. By the time I went to buy it two days later - Lowe's had quit selling it and none was to be found. I went to Woodcraft and used their General Finishes Georgian Cherry Wiping stain. It ended up with the dark red color. It has a urethane in it so in so it does act like a toner to some degree - it doesn't soak in like a pigmented stain. I used it because I wanted to minimize the blotchiness tendencies of the pine. Plus being a wipe on stain you can get more control over color. If you try this product remember to stir well so that the stain and the urethane mix well.
If you want to try the lye "trick" please try on scrap and remember that it will age cherry to look like older cherry. It will not age oak to look like cherry.
Good luck.
Good luck.
