Michael Kellough
Eiji F said:The whole point was to use the LR32 and 1080 to rout holes in a longer guide rail. By using the 1080 rail you know the spacing of the holes will be correct. I just need to come up with the proper set up since the 1080 rail will over lap the rail to be drilled.
I havent even set up or used the LR32 yet, but....
I'm thinking a piece of 19mm MDF wide enough to accomodate both rails with a 5mm deep dado the width of one rail.
I think I will pull the splinter strip off the drilled rail so the dado can capture the rail with out it being hung up on the rubber.
The dado will enable me to use just one clamp for the drilled rail and I can move the clamp to the other side of the jig as I progress with the drilling. Ahhh so many words and so little time. I will make the jig and take some pics.
Later,
Eiji
So you would clamp the LR 32 rail on top off (sort off) the plain rail? The rail to be drilled/routed will be upside down (spines captured in the dados) so the rails are flat to flat? I think the rubber strips won't be a problem.
I think this would work, what do you think Les?
