I am guessing that his might be the "operator" but perhaps you all can tell me what I might expect.
I was trying to cut a 6" hole with the trim router in 3/4" plywood. I was using a 1/4" spiral bit. I made a jig whereby I could pin the center of the hole and just rotate the router after I plunged the spiral bit through.
I could barely rotate the router and it would stall. I could immediately turn it back on...go a little bit and stall again.
Am I expecting too much from the trim router? I thought it would be able to do this?
Do I have a defective MFK 700?
Thanks for the help!
Barry
Barry
