Brice Burrell
- Mar 13, 2007
Final thoughts on template routing with the MFS.
For circle cutting the MFS 400 has a maximum diameter around 32" and the MFS 700 around 55". For template routing the 400 set's maximum size is about 4 11/16" x 12 9/16", the 700 set 12 9/16" x 24 7/16". Combining sets and/or the longer profiles greatly increases these sizes (and the usefulness of the MFS system as a whole).
I've found making overlapping, systematic passes while template routing offers the best results. I always check to make sure I haven't missed any spots and the bottom of the routed area is perfectly flat. Be sure to test fit your work before removing the template anytime you can, it is difficult is get the template back exactly where it was to rout a missed spot. Another tip, test your bit / copying ring combinations on scrap first to ensure the results are what you expect. Remember the MFS is as accurate as you set it up to be, so give it the time it requires. Calipers help me set the MFS for smaller work were the routing being off the tiniest amount is not acceptable.
Adding profiles with the angle stops to the outside of the template helps to place and clamp the MFS.
The anti tilt insert is made to fit 24, 27, 30 and 40 mm copying rings, what if you want to use Imperial sized guide bushings? No problem, just use the router's support foot (outrigger) to do the job. Holding the router flat on the template is the key, if the router tilts it can ruin your work piece, so exercise care. One more very important thing to mention, let the rout bit come to a stop or release the plunge mechanism before lifting the router out of the template! In the bit contacts the template you could damage the bit and most certainly cut into the profile. If the profile is cut were the bushing rides that edge of the profile will no longer produce true cuts. The profile is not ruined, it can be turned to have the blemish facing out or turned upside down. However, scale won't be able to be used, greatly affecting ease of setup.
You'll notice the router's dust collection is not as good while routing with the MFS, the open space the template creates lets chips escape, these chip find there way into the profiles. If you let the chips built up in or around the profiles they can affect the template accuracy by getting between the copying ring and the template. I take time to vacuum off the template as needed. Placing the template on the work piece perfectly flat is a must, check to make sure it still flat after you have clamped everything down. Again, make sure no chips are under the template.
What I've shown in section are just some of the routing jobs that can done with the MFS template. With a little practice (and imagination) you'll be able to do projects that you thought were beyond your skill level. If you are a novice woodworker, the MFS can have you creating more complicated projects in no time. Once you have a grasp of the basics, it's pretty easy to build on those skills. Because the concepts are the same from the simple mortise, to the more complicated routing tasks like intricate inlay work, your skills will build quickly. For the more experienced or the professional woodworker, the MFS simplifies some of the routing jobs we used to do with custom wooden or single purpose built jigs. If you happen to have accurate, well made custom jigs, be all means use them. Building custom jigs can be time consuming, sort of a trial and error process. That's time I'd rather be spending some other, more productive way. Plus, I'm glad not to store custom jigs anymore, I have a notebook, with what Ned Young calls "recipes", of the MFS settings used on past jobs. Sure you have to spend time assembling the template each time you want to use it. I happen to feel the flexibility the MFS offers out weights the small amount of time spent on setup. Accuracy of the MFS is far better than almost any wooden jig I've ever made. My final comments on the MFS as a routing template, no matter if you are a beginner or a pro, the MFS is: fast and easy to setup, the routing is accurate and the results are great.
Text, graphics and pictures, copyright 2008, Brice Burrell
