ThisVeteranVlog
- May 14, 2020
H532P said:H532P said:BenMarshallDesigns said:[member=75102]H532P[/member], I would double check that the narrow stock you're using is in fact square. Also, it's rather hard to keep such a narrow stock held firmly against the stop ruler and have it remain square through a cut (the more reference contact the better). I have many videos on my YouTube channel on how to square the MFT/3. I would encourage you to look up Festool USA's method for squaring just the stop ruler and miter to the guide rail (opposite of my method, and might be better in correcting your error).
[member=73012]BenMarshallDesigns[/member] Thank you very much for the reply! I have watched your videos and I really enjoy them. I have not tried your technique using the TS55 as the “square” because I am initially hesitant to mess up the factory placed stops. Perhaps I should try it at this point...
Also, isnt the point of cutting on the MFT to square the stock itself?
Thank you for the reply and help, I appreciate it very much. Keep up the helpful videos! I’m a subscriber!
[member=73012]BenMarshallDesigns[/member] Are you really able to cut perfectly square cuts with no issues on thin stock (think 2 inches wide) and 20+ inches long? You’re not seeing any cuts that are 1mm off at that length?
Yes, I get really good results with my MFT/3. Took me a while to dial it in, but I've got it super accurate now. I've got a video on my channel on how to rip thin stock with the MFT/3
