Hnnguyen85
- Sep 16, 2015
I've been long overdue for an out feed table and didn't have the space until now. I gave my torsion top assembly table away to make room and was able to put my tablesaw in its place. The table will also serve a cutting plaform for my tracksaw. The top for my out feed table is 3/4" MDF and all holes were cut on the cnc router at my work place.
I had about a 2 foot drop off from the MDF sheet so I decided to route the holes on the drop as well. My plan is to make a fold down extention wing for extra support when cutting sheet goods on the table with the ts55.
I had plans to add bottom full extending slides for my systainers to sit on but ended up not having the clearance for it. I had to put the middle shelve high enough to clear my dust port so it no joy there. The gap however does fit my systainers foe the ts55 perfectly.
