jmbfestool
Rick Christopherson said:galwaydude18 said:Joiner 1970 Can you use the plunge lock for changing to blade to make a cut instead of changing the blade?
No, the FastFix lever also locks the arbor from turning. However, the TS 55 REQ does include a new, second FastFix depth lock that is nearly full depth. It is deeper than the blade changing depth, but still locks the arbor. To activate the deeper one, you need to plunge the saw below 30mm before opening the FastFix lever.
However, if I was trying to set the saw (any saw) to a critical angle, I would still use a cut-and-test (trial and error) method. That even includes setting the subsequent Domino fence to a precise 45 degrees, too. This is because whatever method you use to measure your 45 degrees will have only a 1x accuracy, but your finished joint will have a 2x error.
I agree with you?!?!?!? [bite tongue]
I agree best way to set 45 with TS is trail and error. I have tried many times using using 45 bevel gauge and its always out. Like said only have to be slightly out and its doubled.
I dont think the TS saws are brilliant anyway for BANG on 45 cuts even if you have done the trail and error method.
You gotta clamp the rail, you must apply pressure on the base to guarantee it to not tilt every so slightly. A sharp blade MUST be used to avoid it going off.
You also gotta cutting it square first remove the bulk of material then angle cut it.
If possible I use my router with 45 router cutter! Much better bang on!
