tiralie
- Jan 26, 2010
Julie:
Great job on the doors.
Like others have stated edging the counter with mahogany or sapele will be problematic. While there is a grout that the flooring guys use to join tile to wood, as Peter says with all the moisture around the sink etc. there will eventually be problems.
1) I don't have experience with stone but I would think the best solution would be to edge with the same granite that's you used on the top. Ideally you would want the top to cover the edge vs. having the top of the edge showing with a grout line. This means routing out a space so you can glue and grout the edge in. That's a big job.
2) You could edge with black anodized aluminum or similar.Since you are installing stainless steel appliances you might want to consider the schulter stainless steel counter top edge.. (I just checked they make a black edge as well) This would compliment your design (black edging) and be relatively easy to keep clean etc. This will probably involve custom fabrication.
Yes either tone them to look like the doors, or paint them. There is a lot (color, wood grain tones) going on in that kitchen.
Like others have stated, No. This will make the kitchen look dated and ruin the "less is more" design aesthetic the doors have created.
Don't change it. While I don't like it, it makes sense to see a "bar type" edge in front of bar stools.
Tim
Julie Moriarty said:1. On the edge of the countertop we were thinking of installing either mahogany or sapele and breaking the edges slightly with a 45 cut. But recently I'm wondering if we should consider some sort of granite edging instead. I don't know if something like that is even made or it we would have to have a stone company custom make it, but in my minds eye I think it would make the granite tile countertop look more finished. We would have gone the slab route but it would have broken the bank. Any thoughts?
Julie Moriarty said:2. Should we change the window colors and wood trim to match the kitchen or keep it matching the rest of the house?
Julie Moriarty said:3. Should there be a valance between the cabinets over the sink, or no? If yes, how wide? And should it be profiled or straight?
Julie Moriarty said:4. The bar nosing on the chair side of the countertop (2nd pic down), it's made from red oak and the color matches all the wood in the family room. If we install sapele or mahogany on the kitchen side of the counter face edges, should we make another bar nosing to match, or just leave it? If we matched it, we would probably have to replace the oak paneling below with sapele paneling.
Tim
