B BUTTER Member Joined Jan 28, 2008 Messages 267 Jun 25, 2015 #1 Are the new 18V compact 2.6aH batteries backwards compatible with a C12 PC1213S?
AlexThePalex Member Joined Nov 12, 2008 Messages 7,808 Jun 25, 2015 #2 No, they are not. You can never use higher voltage batteries in a lower voltage tool. The batteries are keyed so you will not be able to insert a wrong battery in the wrong tool.
B BUTTER Member Joined Jan 28, 2008 Messages 267 Jun 25, 2015 #3 Alex said: No, they are not. You can never use higher voltage batteries in a lower voltage tool. The batteries are keyed so you will not be able to insert a wrong battery in the wrong tool. Click to expand... Are there new generation of batteries compatible with these old C12s? If so, can you tell me their price?
Shane Holland Festool Dealer Member Joined Jan 22, 2007 Messages 11,163 Jun 25, 2015 #4 Joseph, That's the older NiCad/NiHM version of the C12. You can only use the NiHM batteries with it. They are $81, here's a link: https://www.festoolproducts.com/Festool-494522-Battery-12-Volt-3-Ah-NiMH-p/494522.htm The NiCad batteries were discontinued. Shane
Brice Burrell Member Joined Mar 13, 2007 Messages 7,386 Jun 25, 2015 #5 Shane Holland said: Joseph, That's the older NiCad/NiHM version of the C12. You can only use the NiHM batteries with it. They are $81, here's a link: https://www.festoolproducts.com/Festool-494522-Battery-12-Volt-3-Ah-NiMH-p/494522.htm The NiCad batteries were discontinued. Shane Click to expand... I'd be very hesitant buying NiCad batteries since they have likely been sitting on shelf for years slowly going bad.
Shane Holland Festool Dealer Member Joined Jan 22, 2007 Messages 11,163 Jun 25, 2015 #6 Brice, I'd be really surprised if anyone even has any of the NiCads left in stock. They've been discontinued for quite a while, primarily because of environmental laws in Europe prohibiting them, as I understand.
