jonny round boy
- Jul 21, 2007
Just got back from my Festool dealer, and the Festool rep was there with a BRAND NEW TOOL that's due out in *I think* October in the UK & Europe. And it's one HELL of a beast!!! Before he got it out he described it as looking like something out of 'Alien', and he was not wrong.
I did ask the rep if I could take some pictures of it to post on here, but he said no
so my description will have to suffice for now.
It comes in the larger of the two maxi-systainers, and it's a drywall sander. It comes in 3 sections - the 'head' unit, which is a approx. 10" random orbit sanding disk, powered by an attached motor which is extremely small put very powerful. The disk is completely surrounded by a circular brush (like on the RAS sanders), though it looked like a section of this ring (about a 1/3rd) could be removed for sanding right into corners. This is connected via a universal joint and a short section of flexi hose to the arm, which has a 'quick-fix' electrical/mechanical connector on the end. This connector links it to the second section:
The second section is the 'Handle', which has all the controls on it - the on/off switch, speed control, and a control which alters the amount of suction from the vacuum. It is connected via a standard plug-it cord & hose port.
The third section is an extension piece, which can be fitted between the two to lengthen the handle. These can be used in multiples for sanding high ceilings.
Like I said, it's described as a drywall joint sander, and can be used to sand down joints on walls & ceilings, though it can also be used as a floor sander, and to sand concrete, too.
Because plaster/concrete dust is very agressive, it CAN'T be used with standard CT extractors - it's designed to be used with a self-cleaning SRM extractor (he did demo it using a CT22, but said that prolonged use would damage the CT. Also the extraction rate on the CT isn't really sufficient).
All this is from memory, so may not be 100% accurate, but I think he said it would be out here sometime in October, and it would be around ?1300 (presumably ex-VAT!) for the sander & SRM combined. The part number for the sander is LHS255, and it's called 'Planex'.
edit: just done a search, and found a picture of one on the German eBay site.
edit 2: There seems to be some confusion as to wether the p/no is LHS255, or LHS225 (that eBay listing shows both!).
Edit 3: The question marks above should be pound signs (GBP), but for some reason they've changed!
