MrToolJunkie
- Jul 6, 2009
It would be nice to see specs...cfm, run time, etc.
Cheese said:Paul_HKI said:That's what it is alright - variable suction/bypass adjuster ring.
That makes up for the lack of variable motor speed.
Coen said:There is a difference between being compatible with dual 4.0 and being compatible with larger single batteries too.
A certain other brand has 8.0 and 12.0 batteries. A matter of stacking the 4.0 Ah 21700 cells just like a 5.2 Ah is two rows of 18650 cells.
Paul_HKI said:I've seen the CTC-SYS in person and I was initially very pleased to see it's going to be available.. The shine went off that very quickly. Rant follows... The 4Ah batteries are right up there with the Bott/Sys3 decision as far as I'm concerned.
It's a major disappointment to me that the new CTC-SYS won't take the 5,2Ah batteries. And it definitely won't, as it needs a pair of batteries to run, but has been designed to take only the 4Ah batteries. The 'new' ones which are made in China. Which I will never, ever buy.
I've bought 4 CTL-SYS over the past number of years. It's a real PITA that I can't get the Cordless/BT enabled one I'd wanted, but I'm not paying Festool prices to swap out my CTL-SYS, only to have to pay more Festool prices to buy Chinese batteries to go into those new CT's. That is just not happening.
If the batteries are not made in Europe, I'm not buying them. And if I need chinese made batteries for a Festool tool, I'm not buying that tool either.
The KSC 60 is really nice kit. I'll be having one of those as soon as they're available.
Pixeltim said:I’m glad I’m not alone when it comes to buying stuff from China.
We are totally screwing ourselves with every dollar we send them.
squall_line said:Guys, let's not get too off-topic... This line of discussion can quickly lead to breaking the "no politics" rule on the forums...
SRSemenza said:squall_line said:Guys, let's not get too off-topic... This line of discussion can quickly lead to breaking the "no politics" rule on the forums...
What he said ^^^
Regardless of it not being technically political, this looks like a discussion for you guys to have privately if you like.
There is more than enough of this type of topic all over the internet. It really isn't needed on FOG.
I don’t think that this is really the idea of cordless tools. You can apply the same logic to drills, but that quickly becomes impractical.DeformedTree said:does the CT-SYS come with a dual battery charger? or have a way to just charge them in place?
I'm rather thinking this is a case they should have just built a battery pack into it, more like their recent power station, just build a module from that into this. If you have to keep 2 matched batteries around for it, and you are stuck with a certain size, having them be the system batteries doesn't get you very much. They could have fit more battery in the same space if it was just integral. As long as it's a chunk that could be replaced down the road if needed, it would be fine.
