- Jan 16, 2007
poto said:Hey Eiji - off topic, but since you brought up the problem of your eyes adjusting when you go from inside to outside on a sunny day, you might consider doing what the pirates did: wear an eyepatch! The eye patch will stop one eye from adjusting to the bright sun so that when you go inside, you just lift it up, and presto - you can see! Pre-adjusted for the dim light. It really works. I saw it on Mythbusters, so it must be true!
Poto
P.S. Bet I'm the only person in Hong Kong right now wearing a Rotex anniversary Festool watch!
I think you can take eye patch many steps further: one eye can be used for metric and the other imperial.
As to the MDF, plastics HDPE, Formica, or any other top, it seems to me a lot of work and expense to improve a product that is pretty damn good as it comes out of the box. Do keep in mind that if you add any thickness at all, the Festool clamps may not work. Of all the suggestions, I like the paste wax one best...or shellac from a spray can. I use both on my jigs -- shellac and then wax.
