brb said:I was just about to take the plunge on my first vacuum, today actually. Now to hold out or not?
promark747 said:Will the new bluetooth/manual button on the hose operate essentially the same way as Rick Christopherson's MAXSYS product? The MAXSYS has been a godsend for convenience.
Cheese said:What would be nice though is if Festool redesigned the boards for the MINI & MIDI and at the same time incorporated the extra circuitry needed for the BT option on the new circuit board, as space within the vacs is tight for add-on modules.
Phil Beckley said:promark747 said:Will the new bluetooth/manual button on the hose operate essentially the same way as Rick Christopherson's MAXSYS product? The MAXSYS has been a godsend for convenience.
Hi
Press the button on the end of the hose and this is picked up by the Bluetooth module.... [smile]. If a Bluetooth battery has been 'paired' then this will automatically start the extractor when the cordless is switched on.... [smile]
rg
Phil
Bob D. said:Phil Beckley said:promark747 said:Will the new bluetooth/manual button on the hose operate essentially the same way as Rick Christopherson's MAXSYS product? The MAXSYS has been a godsend for convenience.
Hi
rg
Phil
If I understand you correctly Phil the BT remote on the hose end will not actuate the CT unless the CT has been paired with a BT battery, even if that battery is not in use at the time.
So, if I had a BT battery paired to the CT, and was using a tool with a battery other than the BT battery paired to the CVT, I could start/stop the CT using the manual remote on the hose end.
But, conversely, if no BT battery has been paired to the CT the manual remote button on the hose will not work.
Magpal said:The new hoses looks very nice. How is the flexibility compared to the old hoses? Do they exhibit the same "memory effect" as the old hoses when they are stored in the hose garage?
The bluetooth vacuums are also great! Would like a MIDI with bluetooth though.
Alex said:Magpal said:The new hoses looks very nice. How is the flexibility compared to the old hoses? Do they exhibit the same "memory effect" as the old hoses when they are stored in the hose garage?
They're probably even stiffer. It's the same hose with an extra sleeve.
But I find hoses are only stiff when they're new. After a couple of months of use they'll become more supple.
Phil Beckley said:Hi
Tomorrow I will post some more images of the hose ..... [smile]
Peter Halle said:Alex said:Magpal said:The new hoses looks very nice. How is the flexibility compared to the old hoses? Do they exhibit the same "memory effect" as the old hoses when they are stored in the hose garage?
Alex, they aren't the old hoses with a sleeve. They are more flexible and lighter. The outside of the hose is smooth and the interior ribs are smaller I was told. If you look at the image that Phil posted with the hose around a piece of wood you will see what I mean. I asked if I could take the end off of the one I saw but was asked not to whereas that was the only one Festool USA had at the time.
I love the fact that for transport you can loop it together and lock it together and that if you need a longer hose you can lock two together without any additional fittings or changing our hose ends.
Phil Beckley said:Chris Perren said:BlueTooth Battery Packs? Is that new or already available?
....new for Europe 2018
Rg
Phil
