New products for January 2018 (Europe) - Facelift for 26, 36, 48
antss said:
[member=1619]SRSemenza[/member]  is the inside of the hose smoother to allow for better airflow ?  Or is it still corrugated like the current versions ?
.....slightly corrugated
Rg
Phil
Here's a nerdy question for you [member=41214]Phil Beckley[/member] which I realise this question may be one for the boffins in the Festool dungeons ;) Is the Bluetooth wizardry a proprietary system or is it using a common standardised Bluetooth protocol?
The reason for asking is the hope that the assorted tool manufacturers bringing out Bluetooth enabled vac-activating tools are indeed using a standardised protocol so, for example, Tool-M from Company-M can remotely switch on a vac from Company-F and vice versa. The letters I chose are purely coincidental and nothing to do with my Makita LXT kit nor my Festool vac of course.
Rg
Phil
[member=41214]Phil Beckley[/member]    - the same or less "slightly" corrugated than the current versions ?
Phil Beckley said:
Peter Halle said:
Alex said:
Magpal said:
The new hoses looks very nice. How is the flexibility compared to the old hoses? Do they exhibit the same "memory effect" as the old hoses when they are stored in the hose garage?
They're probably even stiffer. It's the same hose with an extra sleeve.
But I find hoses are only stiff when they're new. After a couple of months of use they'll become more supple.
Alex, they aren't the old hoses with a sleeve.  They are more flexible and lighter. The outside of the hose is smooth and the interior ribs are smaller I was told.  If you look at the image that Phil posted with the hose around a piece of wood you will see what I mean.  I asked if I could take the end off of the one I saw but was asked not to whereas that was the only one Festool USA had at the time.
I love the fact that for transport you can loop it together and lock it together and that if you need a longer hose you can lock two together without any additional fittings or changing our hose ends.
.....what the guy above said  [cool]
Rg
Phil
Perhaps this will answer your question about ribs. (added highlighting to quotes)
What I’m waiting to see is how much easier it will be to put a 36mm new flex hose in my existing Shop/Tradesmen  Cleaning Systainer kit compared to the old/current 36mm hose it comes with.
The old hoses always fit, but more flexibility for a stock vac kit like these would be great.... [tongue]
It will be much easier. The hose I got to check out was the D36 and it was more flexible than a well used D27.  [thumbs up]
I wish there was a conical hose 50mm to 36mm to hook up to the Kapex and hopefully improve dust collection...
.  WOO HOO.....
Video posted with pairing instructions. I'm surprised to see that you can only pair one battery at a time but 5 of the remote controls. Would have expected it to be the opposite.
I watched the video and it states:
"Only one battery pack can be paired to the mobile dust extractor at a time."
"Registering a new battery pack cancels the pairing to the previous battery"
Does that mean I can't use a TSC & a cordless Carvex at the same time without:
1. Swapping the same battery out between the TSC & Carvex?
2. Re-registering the battery packs everytime I change between the 2 tools?
3. Using 2 different vacuums?
Would option 4 work? Use the remote button instead of pairing the battery.
.....you can pair 5 battery packs to the receiver on the extractor!!
Rg
Phil
I agree this is odd.
If you are constantly switching between cordless tools, you have to pair each too to the vac, each time you want to use the other tool.
At least that is what the video says.
Also every time you're plugin the battery onto the charger, pairing is lost.
I think that needs clarifying or the whole system is just poorly though out.
In certain circumstances, this auto decoupling is a good thing.  In intensive worksite use, a multitool, multivac scenario allows free interchange of tools & batteries without unwanted, inadvertent activation of vacs.
I really, really like the look of those "Electrolux" hoses.  The old corrugated versions were always troublesome buggers around guiderail ends & arrises.
As possible interpretion of 0:57 of the video is that there is a need to preface each use (power-on) of the tool with a press of the button of the vac.
Should the battery auto-depair from the vac (thus their connection simply being a glorified one-time auto-off of the vac) the system would IMHO be completely useless.
I really hope that this is a flaw of the video, not the system.
No idea thought why only one battery can be paired with a vac at any time, while 5 remotes can.
Being able to only pair one battery at a time makes it look pointless for setups where you swap tools...
That mechanic is IMHO reasonable.
Like I suggested earlier, just use the remote button at the end of the hose and don’t even mess with pairing multiple batteries. That is how the MaxSys works and it works fine. Your going to be using the hose anyway and the remote is right there. It is not as simple has just pulling the trigger on a tool and the vacuum comes on, but sometimes I prefer to have the vacuum run longer than the tool anyway.
With all of that said, I would still think with today’s technology that there must be a way to pair multiple batteries to one sensor. Someone else already mentioned this, if you are working with someone else that is also using a paired tool, they could inadvertently start the vacuum. Now if you work by yourself, pairing only one battery would be frustrating.
[popcorn]
When I first heard about Festool's remote, I was surprised that they were using Bluetooth. Bluetooth is a serial communications format. When all you are doing is turning something on and off, why do you need "data", when all you really need is a unique ID for each transmitter? And depending on the class, it also has a very limited range.
But these inconveniences of only pairing 1 battery at a time, and everything de-pairing when the vac is unplugged are deliberate designs. I don't know why it would be deliberate, but it is nevertheless, deliberate design. It's one thing to make it easy to un-pair a tool that's not being used with the vac, but Festool took that too far and made it "mandatory" without giving the user the option.
If you're switching back and forth between a couple of tools to do an operation, you have to walk back over to the vac to re-pair the tool every time you switch. It kind of defeats the purpose of triggering from the battery in the first place.
Ya I’m still confused over this one. I’m still hoping that the Festool video is incorrect.
The video does seem to make it very clear that it can only pair one battery at one time.
It’s not like it was a single word miss type like JMB speak.
Based on the video it seems the bluetooth battery option is not the way to go.
You gotta swap the hose from tool to tool any way so you might as well just have the single transmitter on the end of the hose.  Otherwise your just going back and forth to the vacuum to pair batteries so you be paying more money for something more inconvenient.
I think I’ll be getting a hose with transmitter won’t bother with the blue tooth batteries waste of time and money after watching this video.
