Timtool
- Mar 13, 2011
I had to trim some edges, and usually i do this on the router table but this time there were curved parts.
So i came up with this jig, it's a simple piece of 5mm trespa that covers half the base and extends outwards for additional control.
I simply used the baseplate as a template for the holes, to attach it you simply unscrew the baseplate and screw this one in place.
[attachimg=#]
I put a 45 degree chamfer bit with bearing on the router.
the "missing" part of the base allows the sticking out edge of the trim to pass under the base and be trimmed. This allow to work with the router standing up and you can also handle curved parts
[attachimg=#]
[attachimg=#]
Here you see the result, it works extremely well with a much better finish than i had by using the router table.
It is pretty much fool proof, i did somewhere around 60m of trimming, and made no mistakes or chips. I even trimmed the short edges with it.
Because it is trimmed at 45 degrees the edges feel smooth and only require a light pass with sandpaper to get rid of the glue here and there.
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
