Sam Murdoch
 - Apr 13, 2008
I have just started using my new OF1010 - just have the basics- whatever came in the box. I have had 3 or 4 reasons to use the edge guide that rides along the guide rail attached to the router with metal rods. (I have no idea what all the various doo hickies are actually called so I will do my best to explain rather than spend an hour on line trying to determine the exact terminology. Sorry in advance if I fail to make myself clear.) Have been frustrated because my routing was being done too close to an outside edge so that the little sliding side support foot that is intended to level the router base to the work surface while using the edge guide (it sits off the work surface the thickness of the guide rail) was not supported by my work surface. So, the first time I just had to give up. The second time however, I was determined to make something work without reinventing the little sliding foot suspended with a sky hook, or something like that. After a few failed attempts I went back to the systainer to see what else I might have in there. Discovered the plastic guide bushing adapter all set up with screw holes to be attached to the base. Also discovered that you can screw that adapter onto the base without removing the inner black ring already in the base, using longer longer screws. Do so with the protruding inner circle facing out and now the router base is automatically set up off the work surface equal to the thickness of the guide rail. For you engineer types out there I did not do exact and precise measurements but for running 15" sliding dovetails if there was any misalignment it was absolutely negligible. Anyway, problem solved. Found the longer screws to screw through both rings in my Bosch router base. Thought this was worth passing along.
Speaking of screws - there are staight slots, phillip heads, tourque drives, combi drives, toilet stall one way screws (why?) and then there are Festool router base screws [huh]. What is up with those things? What kind of screw driver are you supposed to use with those and why isn't that included with the router? What a miserable little pain [sad]... Are those really necessary?
