Brice Burrell
- Mar 13, 2007
There were a couple of recommendations to use water based poly over the latex, that should take care of the problem.
Brice Burrell said:There were a couple of recommendations to use water based poly over the latex, that should take care of the problem.
Brice Burrell said:Jim, honestly, I would use the water-based poly. I don't have a lot of experience with latex enamel paints so I can't really give any helpful advice there.
Peter Halle said:Jim,
There is another Benjamin Moore Product that you could consider. It is called Advance. It is a water based enamel. That does not mean latex. It means that it is a hybrid. The water in the mixture is used as a carrier that will evaporate relatively quickly (like latex paint), but the remainder is an oil based enamel. It has all the characteristics of an oil based paint but cleans up 99 percent with soapy water. The brush will then have an oily feel to it. That you clean out like when using an oil based paint.
The finish dries to a hard film and needs to be applied like an oil based - i.e. apply and then don't fool with it or overbrush. Only comes in satin and gloss though.
I did run across another product there last week and can't remember the name. I will get it for you. If I can find it on their website, I'll be back in a couple of minutes.
Jerry White said:Jim,
If you used Benjamin Moore Waterborne Satin Impervo, 100% acrylic enamel you are in luck. The key term is acrylic, although it is called acrylic latex in the description on the back of the can, it is by no means the same paint as latex wall paint. I have had very good results using this product on trim and shelves, even shelves that receive hard wear. I also add a product called Flowtrol to improve the self leveling of the finish.
Good luck with your project.
Jerry
The manufacturer is Insl-x
Product is Cabinet Coat tirm & cabine enamel
Composition is urethane acrylic satin
Clean up soap and water
Jim Kirkpatrick said:Hi Jim, Here's what I do and get great results:
1. Sand bare plywood to 220 grit
2. Apply Kilz brand oil-based primer....oil based will not raise grain and sands very smoothly with minimal effort. I used disposable brushes and rollers for the primer. Avoids icky cleanup. Foam brushes work great for trim. If you are using a dark top coat, have them tint the primer at the store. Also have them shake your cans (that's what she said)
3. Sand primer with 220 grit.
4. vacuum up dust and wipe with tack rag
5. Apply latex semi-gloss paint, I like Sherwin Williams or Ben Moore. Don't go cheap here. I use a Purdy sash brush for latex paints on trim and a good quality roller for field. I always go back over rolled areas with wet brush to even out and give it a brushed appearance.
6. Repeat step 4 in between coats, 2 top coats should be sufficient.
Here's a picture of my golf lockers using the above advice:
bjackson3 said:I don't like the smell of oil primer so I'll use a good Ben Moore latex for the primer sometimes on birch plywood, etc. instead of the oil. You do not want to use latex primer on mdf though. Mdf does not react well to water, even the amount of water in latex primer, so on mdf always use oil primer. Once the mdf is primed, you can use a latex paint on top.
Also, if you rout any profiles on the mdf edges, etc. then just be a little gentile in sanding though, the edges of mdf are a bit softer and will sand through quicker.
