I experienced a problem today and don't know why it occured.
I was edge gluing some 80" long cherry boards for a headboard. The first Domino was cut at the smallest setting and the rest were cut on the middle setting.
The first domino was started and registered by the built in pins. I then used my cross stop attachments to put the middle width hole for the rest of the length of the boards.
Both cross stop, left and right, are set on the same scale marking.
I cut about fourteen mortises along the length.
Obviously the distance of the pins on my cross stops were not the same because I had a small variance that multiplied with each new mortise and by the end they were off by a full 1/4 of an inch. I know that the pin was tight and against the prior mortise each time since this happened on multiple boards and the variance was gradually built, you could see it get larger.
What could cause this to happen?
	 Most seem to dislike the out riggers. You are best to make a quick mark with a pencil.  Below is how i mark mine out. Its simple but it suits me.
 Most seem to dislike the out riggers. You are best to make a quick mark with a pencil.  Below is how i mark mine out. Its simple but it suits me. So i put the dot (usualy blue masking tape) on the left and that tells me what side to start with the Domis index pin. That first cut both sides is on the exact setting.
