galwaydude18 said:
Did u use 6mm for the flat panel then 12mm for the rails and stiles? Route the profile on the rails and stiles and mitre the corner of the profile and glue it all up in that jig then?
I'm guessing here to be honest
I used materials which were already on the job as left overs.
Had a full 9mm sheet of green MDF 18mm MDF and some hard board.
That's why the door is abit of a miss match in colour but hey who cares being painted.
So what I did
Made few rip cuts at 150mm wide with 9mm MDF
then
with my thicknesser I thinned the 9mm down to about 2mm
then
I glued 8 layers together and curved them in the curvo matic
while the two 150mm wide strips
then
Made the beading which I didn't bend I actually cut the curve pieces with jig saw and Routerd the mould onto them.
then
I would of liked to thinned down the 9mm MDF again for the solid back but wouldn't fit in my thicknesser so I decided to use the hard board as its thinner in the first place glueing up 3 layers. Not recommend just 3 layers as u do get slight spring back very slight I got zero spring back with the MDF 8 layers.
then
the 150mm pieces I ripped down to 65mm for the rails so I got 4 from the 2 I glued up.
then
when the hardboard was solid I marked out where I wanted the styles and rails and glued them onto the hard board placing them back into the jig.
then
Cus I just used the 18mm for the styles they didnt have curve I shaped them with the rotex one with slight hallow other side slight round. Wasnt going to spend time just glueing layers for the styles for such a small amount if curve wasnt worth it.
then
I fixed the beading on. It was but awkward getting the angles for the mitres.
Done???
