ear3
One vertical, one horizontal, and one diagonal. So much for consensus.
Got through the doors and the rest of the drawer assembly today.
One of these days I'm going to get a real bandsaw so I can resaw my boards and not have to waste all that wood to make thin pieces. As it is I took down a 4/4 board on the planer to 3/8" for the door panel. One silver lining was that to make the dado for the panel I got to use the 3/8" straight bit from my 72 piece Ryobi close out special, which was my very first router bit set more than a decade ago. I keep it around just in case, and this turned out to be one of those cases:
Doing the assembly on the doors:
Then moved on to the drawers. Cleaned them up a bit with the block plane so all the sides were flush:
To keep the drawers sliding straight, I also added a runner in the middle, which fit in between two boards attached to the underside of each drawer. Had to bring down another piece of oak to 5/16" -- fortunately this wasn't as much of a waste, since the board was the discarded first attempt at the bottom shelf:
Cut the board into one inch strips, and then made a 33/32" spacer to give the slide a little play on either side. Attached two strips to the underside of the drawer with 2P10 glue to make the channel.
Then notched out the back of the drawer
The installation of the runner was a bit trickier. After eyeballing its position through the notch with the drawer pushed in, I got some double sided tape and attached it to the drawer support You really come to appreciate learning to build things square in the latter stages of a project, because you can just rely on a square and know that it is lining things perpendicular to the face.
After making sure it was positioned properly, I marked its position on the drawer support frame, took off the tape, and 2P10-ed it. It was only on the second one that I realized that I could also use it as a back stop, moving it to the front such that the drawer face would hit it and not go in any further. In any case, I sized all the drawers such that there is only 1/16" or so gap with the back -- but next time I know I have more tolerance on the drawer depth since I can use a runner to position the drawer relative to the front of the case
View from the back
And here's the piece thus far.
Still have to do hinges and hardware, as well as figure something out for the top. Those are the actual boards I will be using on the top, but I have to final side them and choose an edge profile.
View from the back
