jeffinsgf said:Does anybody know if the current set (angle arm and copier set) will work with the OF 1000?
Wonderwino said:Nice job, Craig. I'll have to add that to my "next order" list. [big grin]
tallgrass said:how does the rabbit stay even as the router moves around the pivot point? how do different size bit deal with the set size of the copier bearing?
Aegwyn11 said:I have to say I'm confused about this as well. It would seem to me that you would get a different width of rabbet if the center of your bearing is not exactly at the center of your bit. If the center of your bearing is offset from the center of your bit, wouldn't any twist of the router result in a change of the rabbet width? My point is that your distance from edge of bearing to edge of bit would change depending on how the router is oriented (unless your bit is centered under the bearing).
Gaucho Woodworking said:Thank you for those great videos. I just ordered the scanner set for other applications and now you gave me new ideas of applications.
