Steve1
DynaGlide said:The top will be 24" wide, standard split top size. The length is probably going to end up in the 60-72" range. The Roubo is 87" long according to Benchcrafted/TWW plans. I'd be stretching it to get the 72" long. .
One good thing about making it a little smaller is that you may actually be ably to move it, when you need to. All that maple ain't going to be light.
My workbenches fortunately have enough height between the floor and the bottom beam, that I can slide my pump jack under it to lift it a bit, then slide a set of dollies under it.
