tjbnwi
- May 12, 2008
mastercabman said:OKtjbnwi said:mastercabman said:Tomtjbnwi said:mastercabman said:I don't think you canIwood75 said:Thanks Tom. Have another question... Can I get a downcut bit with a top bearing? And it would have to be 1/4" shank to fit in the 1010. Joel
Most down cut bits are solid piece
So in your case you will need a bit that is 1/2" with a 1/4" shank whitch I have never seen
You could look into using a bush guide
Explained the process in post #4.
Other option is 1/4" bit with 1/4" bottom bearing, mount template on bottom of table, drill hole run bearing on template. Issue with this is the sly may come loose if your not real careful.
I agree, bushings are an option also.
I read post#4
But down cut spiral bit are solid bits
If you use(let say 1/2" bit) the shank will need to be 1/4" so that the bearing slide onto the 1/4" shaft
But I have never seen a bit like that with a smaller shaft
If you can post a picture or a link to what you are referring to
Collar-bearing-collar.
But that's not a flush cut set up
I thought the OP was looking for flush copy bit?
When I suggested the method I told him he would need to make his template to make up for the offset (again, post #4).
