grbmds
Please recognize that this is my personal opinion. But festool is a system, the festool router table is specifically designed to be used with festool routers. Other manuf router tables are generic and made to fit other routers.
Plus the CMS does have superior dust collection to other router tables Ive used. It is the same height as the MFT3 so the MFT can be used as a side extension and outfeed table(system approach).
Also The CMS is designed to use with the other components, the saw module and scrolling module which I have, and a belt sanding module which I dont have. These are not available in NA but people seem to get them.
If you add in some of the items in the GE pkg ad that come standard, such as the sliding table, the outfeed table, and the router lift you be paying extra money for them and they would be generic and not designed for use with that particular router/table additionally the left would cost you roughly $300 depending on manuf. Most router tables dont come with the sliding table.
As a bennie the 2200 is the best router that size available on the market. As I said I used a huge raised panel bit with a back cutter and did single cuts ad raised the panel in single passes. and it didnt strain the motor and the motor didnt slow down at all.
As a free hand router I love the 2200. If is so superbly balanced it will sit there and run while sitting on a MFT upside down when accidentally started.
Dont ask mew how I know that.
Try that with the PC router 7518. It will chase you around the shop
Dont ask me how I know that to.
Plus using it with a guide rail is another big plus.
hope this helps
