router +vac
tvgordon
I believe I read a while ago that the routers require the 36mm hose rather than the 27mm hose, is this correct?  Also, do any other tools need the larger hose (maybe the saws)?  I am considering buying a router as my next Festool and am trying to estimate how much I need to spend in "extras", like a vacuum hose, collet, edge guide, etc, etc..  But I already have about six routers, maybe I need another sander - so many choices.
Tom.
Tom.
Tom,
The 27 mm hose fits every Festool tool, the 36 mm hose will fit the OF 1400 and 2000 routers, the HL 850 planer and the 2 TS saws. The 36 mm is not required for any of these tools, but does a noticeably better job at dust extraction on the routers and planer than the 27 mm hose.
  Bob
i agree with Bob that the 27mm hose will work for planer and routers.  I have no problems with using that hose, but I am sure the 36mm would mean i could work a little faster with the planer.  I also use the 27 with my DW 625 that is set up over my WoodRat.  that seems to be the combo that spits the most dust and chips.  i have not found a way to capture all from that tool combo, but the CT 33 and 27 mm hose does as good a job as any other method i have tried.  i will eventually be getting a 36 mm hose to use for that setup and my planer.
Tinker
