rvieceli
[member=25829]JZ Bowmannz[/member]
Almost anything you put in that does an adequate job is going to be noisy especially at high levels. I'm running an external roof mounted 1200 cfm Viking unit. It requires 10 inch ducting. It does an excellent job. I've got an older 6 burner Viking that each burner puts out 15000 btus.
While it's true that you can't really hear the fan unit running much even on high, the noise from the volume of air you are moving is loud at higher levels.
Pay attention to the manufacturer's recommendations as far as mounting and duct size.
