smorgasbord
mino said:I did not say they may not produce good stuff. Just that it is apparent sales/marketing decides not only what is made but also how it is made. That is the only way such an appearance-first, function-second production can happen. I had this feeling about them for a long time. The video just confirmed it.
They do and will keep making good kit. But one should never ever trust a business where manufacturing is decided on by marketing. If they make anything where accuracy matters, make sure to validate it is actually accurate and how much. Nothing more, nothing less.
I do trust TSO. They have an engineering-first culture and keep sticking to it. Over and over. I also trust the Festool engineering culture. WP? No.
Well, lets say I am hard to impress by fancy manufacturing videos. I have learned the hard way that to understand orgs/teams/people one needs to focus on culture (of working/designing) and that is seen in such subtleties.squall_line said:If you watched any tour videos done by the owner of Woodpecker's, or videos discussing the machines where they're making their new router bits, you may change your opinion on that. That said, I don't expect people to seek out nor take time to watch such videos, either, so it's perfectly understandable if you haven't seen them or won't watch them.
Their sales model and "one time tool" model may not be everyone's cup of tea, and there are certainly some odd items in their collection, but to call them a marketing company first and engineering company second is a pretty bold statement.
PaulMarcel said:I've often wanted the Bridge City saddle squares.... For non-square angles, I use the saddle square built into the Bridge City double-square or any of the multi-tools. A hair more awkward, but usually it is already in my hand.
mino said:I did not say they may not produce good stuff. Just that it is apparent sales/marketing decides not only what is made but also how it is made. That is the only way such an appearance-first, function-second production can happen. I had this feeling about them for a long time. The video just confirmed it.smorgasbord said:I strongly disagree. The guy in most of the videos, Jeff Farris is a not just a good participant here (and on the Inca mail list), he's a woodworker himself. Some of the WP videos are shot in his own home shop. And I've never heard anyone complain about Woodpecker's customer service. Maybe their tools aren't what some woodworkers want or need, but overall they're high quality and do what they claim.
Jesse Cloud said:Hans,
For what its worth, my personal view is that anything that can be adjusted will eventually lose that adjustment and need to be readjusted, but its hard to know when so one must double check it again and again. I generally prefer fixed angle gauges. The main ones I need are 90 degrees and the dovetail angles, which Lee Valley makes at a very reasonable price.
For variable angles, how would the product you are thinking about improve over the bevel gauge - which I thoroughly mistrust? [unsure]
Packard said:Shinwah, the Japanese manufacturer of woodworking measuring tools makes their own version in aluminum (about $20.00) and in resin (about $10.00) and available from Rockler, Amazon and others.
I have the resin square and it is very handy, accurate and easy to use. I recommend it or its aluminum cousin.
Not flashy, but well-made and well-thought-out. Their measuring tools have an excellent reputation.
The issue is not the milled sides being co-planar.*) It is them being orthogonal to the hinge.SRSemenza said:The WP milling operation gets done on both sides / edges. Milling the first edge is making the two pieces co-planer and true, much like edge jointing. But not necessarily parallel to the other edge. Then the piece is presumably flipped in the same (maybe a different set up) and the other edge is run.
mino said:A marketing business run by sales people through and through. Nothing bad about it. Just another company not to be trusted.
Think twice and measure thrice before and after buying from this company.
Indeed cannot comment on their jigs and fixtures. Presumably they are good-enough such they can spend their error "budget" this way and still turns out OK.Cheese said:I think not...over the years I've had several conversations with the owner. Richard is all about engineering and precision machining first, the marketing part is a lot further down his list.
As far as machining accuracy goes, it's all in the jigs & fixtures they use for production. We have absolutely ZERO insight as to what their manufacturing set-ups are, yet are quick to declare that they're somehow flawed. [tongue]
WillAdams said:That was my take on the other options as well, and glad to have it confirmed.
Which specific double square do you have which has this feature? It doesn't seem to be on current models:
https://bridgecitytools.com/products/ds-6v2-double-square
A notable difference between the BCTW originals and this latter version is the formation of the hinge --- it is quite a bit more complex on the previous model, and seems a much easier thing to make on the latter --- and being made of aluminum, makes me wonder about the prospects of just making one myself....
Or, maybe just buying a suitable Brusso hinge and using that.
smorgasbord said:Maybe watch this video to see uses of a hinged saddle square:
PaulMarcel said:Sadly, the DS-6v2 doesn't have the saddle square portion. The DSS-6 (double saddle square 6") does and that's always on my bench. The MT-1 and MT-2, though, do have the saddle square along with 2 dovetail saddle squares and a bevel gauge. These are always in the drawer since I use bevel gauges a lot.
Packard said:...
With the exception of the polygons and triangles, my fixed Shinwah saddle square will do all that the folding square can do and without the potential inaccuracies that the hinge brings to the table. I would venture to guess about +/- 0.015” (+/- 1/64th). Just an educated guess on the added tolerance, but it will be less accurate than a fixed square.
Cheese said:mino said:A marketing business run by sales people through and through. Nothing bad about it. Just another company not to be trusted.
