joiner1970 said:
I'm about to build a couple of bookcases and its all drilled out for 5 mm shelf pins just thought Id get an idea of what type others use. I'm thinking the type that you drill a 5 mm hole in the shelf too so it locks them in place or do I just use pegs and don't bother drilling holes in the shelf.
Kind of late to this discussion, but I typically use the following pins which partially locks the shelf in place as is or really does lock the shelf in place if you screw them down to the underside of the shelf.
