- Jan 28, 2018
Thank you for the post, I’m ordering an extinguisher right now!
Birdhunter said:I do not have any Festool components in my router table setup. I’m not sure what the comment regarding Festool discontinuing a product has to do with my fire incident.
Birdhunter said:It is an 18” cube box that hangs under the top surface of a Kreg router table. It has a 4” duct at the bottom that feeds a big cyclone. The box has doors at the front to allow access to the router and empty any wayward dust.
Michael Kellough said:Birdhunter said:It is an 18” cube box that hangs under the top surface of a Kreg router table. It has a 4” duct at the bottom that feeds a big cyclone. The box has doors at the front to allow access to the router and empty any wayward dust.
I’m not a fan of that kind of router dust collection. Apparently the box also accumulates the heat of the router and has enough horizontal surfaces for dust to hang that fire can result. If the router was better ventilated and all chips and dust immediately drawn well away I don’t think even smoldering could occur. At least it hasn’t happened to me.
I like the kind of collection pictured in the link below. The motor is almost completely isolated from debris and it is slowed to breath clean fresh air. Also the hot exhaust from the motor is diverted away from the dust production/collection.
Michael Kellough said:I like the kind of collection pictured in the link below. The motor is almost completely isolated from debris and it is slowed to breath clean fresh air. Also the hot exhaust from the motor is diverted away from the dust production/collection.
Michael Kellough said:@ Mike Goetzke. “you can not c/o router bits from above”
What is c/o?
Mike Goetzke said:Michael Kellough said:@ Mike Goetzke. “you can not c/o router bits from above”
What is c/o?
Sorry c/o = change out.
What is c/o?
Birdhunter said:I keep thinking about what might have caused the embers that triggered the two little fires. I was cutting a stopped dado through 3/4 Baltic using a 3/16” carbide bit. The debris was clogging in the dado. And I was having to scrape it out with a small bladed screwdriver.
I’m guessing that the bit got really hot, the bit heat got above 451 F and ignited some of the chunks of sawdust. The ignited chunks fell on top of loose sawdust I had let collect in the bottom of the dust box. Ergo, fire.
Does that scenario make sense?
I like the kind of collection pictured in the link below. The motor is almost completely isolated from debris and it isslowedallowed to breath clean fresh air. Also the hot exhaust from the motor is diverted away from the dust production/collection.
RKA said:I had to reach into the depths of my gray matter, but I finally found the extinguisher I was thinking of. Element fire extinguishers. It covers A, B, C and K fires. One extinguisher will go for 50 seconds which is substantially longer than a conventional 5 lb cylinder. Price is about $80 ea., so not cheap, but no mess to contend with. The one downside is it’s not as conspicuous as a 5 lb cylinder stuck to the wall. And obviously not intuitive to someone that has never seen one before.
