smorgasbord
- Jan 7, 2022
I'm trying to find some actual 5mm thick plexiglass for some jigs I'm building.
I had some old (as in several years or more) plexiglass lying around that was slightly thicker than 5mm, but definitely not ¼"
I recently bought a small piece from Amazon that claimed to be 5mm, but is actually 4.6mm thick. And I saw a listing on Amazon for ¼" plexiglass that admits it's only 0.220"-0.236" thick.
Since the thickness of the plexiglass affects the depth of cut on my Domino, I want as close to 5mm as possible - if not exact then slightly thicker. I'm thinking of going with the ¼", as 5mm is just about 0.2" so a couple/few hundredths more is probably just fine.
Is all so-called ¼" plexiglass actually just 0.22"-0.236" thick? Is there anything closer to 0.20" without being under? Am I being anal-retentive? (that's rhetorical [embarassed])
