FestitaMakool
Well, I was kind of surprised myself to see that there were not even a hole for the pin.
I was just thinking when you wrote how and why they offer the student version.
(I’ve hear similar stories for other companies
Sometimes cosmetically not perfect samples come off a production line that ends up in a “lesser” but cheaper versions of those who pass all inspections. Instead of write it off, It’s a valid choice to re-use and perfectly fine if it does it’s job as the product it was meant to be in the first place, only with lower grade finish.
The butt end of mine had a small bump in waist section. I’ve done an attempt to sand it flat and in square to the bottom - just in case I could use the small area to butt up against in a tight corner.
I’m sure all of these will serve me well, probably a lifetime if treated well. I’d be glad to pass them down to my sons, once they recognise and appreciate such a tool.
The center finder is something I’ve missed numerous times, a very welcome addition.
I was briefly thinking of a longer ruler with the 12”/300mm square, but would it be useful?
The heads base isn’t exactly long.. and I fear it will be a waste with a longer ruler.
Do you have experience with it?
I found that I can use the 6”/150mm ruler on the large head, but the 12”/300mm will not fit the small head. The 12”/300mm ruler is slightly thicker, and therefore doesn’t fit.
