Subcompact cordless screwdrivers
sae
Anyone have something they like? I've been looking for something sub-CXS class in the 3.6/7.2v world. Like palm driver sized.
I think the Snap-On CTS661 comes closest to filling all my requirements. Those are:
  • palm sized (no folding ones, which all seem to be too long)
  • no silly gyro function
  • variable speed trigger
  • locking bit retainer
  • adjustable clutch
Unfortunately it's pretty pricey ($275 retail [eek], although used, ~$120).
My runner up is the Bosch GSR Mx2Drive, which is tiny, but it doesn't have an adjustable clutch unfortunately, and NAINA, though I think I can source it.
Another option is the Bosch/Skil IXO, and they do have a clutch attachment on their IXO, but it's pretty weak. Seems like it struggles with anything bigger than a drywall screw, and no variable speed trigger. They do have offset/right angle chucks available, as well as cork screws, peppermills, and other fun accessories.
Ryobi has a 4v that's in the class, but it's bigger than the 7.2v stuff, and heavier.
Metabo makes one, but the grip looks enormous.
That's as far as I've gotten so far. I'm sure I've made some glaring omissions.
Frankly that Snap-On doesn't look like it's much smaller than the Milwaukee M12 driver. But what are you going after?
• lightest weight?
• Shortest body?
Your answers may help us help you, but you may have already identified the ones that are closet to what you are looking for...
I have the Milwaukee M12 Fuel screwdriver, the grip of it is nice, one handed chuck is really nice, but head of it is large, and it's top heavy.
I'm looking for something smaller, more balanced, it'll be my go-to gun for cabinet assembly.
The Snap-On gun has a rocker switch which I'm not crazy about.
The non-fuel M12 is smaller, but I don't know if it's small enough for you. It's my go-to standard drill/driver for what you are talking about, even though I also have the fuel version.
OTOH, my M12 Fuel impact is actually my favorite impact drill/driver. Love that little monster...
I like this hitachi driver:
http://www.amazon.com/Hitachi-DB10DL-10-8-Volt-Lithium-Ion-Driver/dp/B0013DN4NI
since the battery itself is on the base, it balances the weight of the head nicely. In addition, the grip is skinnier than the other offerings with the lipstick battery in the grip.
It appears though that Hitachi is discontinuing this version. It looks like the chucked drill and the impact driver in the same form factor are most readily available. You can find this model through ebay and a couple of resellers. The batteries and charger are all the same so that should not be a problem.
I think there are several that work well but for slightly different uses.
I like the Milwaukee 2.4v but it is of a type that is straight or folding, which you said you didn't want. That works well for me for small screws, particularly in electronics. I use it intermittently so the later 4v Lithium, which are actually 3.6v of course, would be better since NiCad loses its charge over time when not used.
I think the Bosch PS20 probably fits your request. It weighs virtually nothing and is comfortable to use all day long. I have several that are used in semi-production of display cabinets. Amazon has them for $89 including charger and two batteries:
http://www.amazon.com/Bosch-PS20-2A-12-Volt-Lithium-Ion-Batteries/dp/B000PI5EBW/ref=sr_1_1?ie=UTF8&qid=1423512659&sr=8-1&keywords=bosch+ps20
This later PS21 probably is more flexible if you also want to use it as a light drill but the PS20 is better as a medium size screwdriver.
When you get bigger than that, I like Impact Drivers.
I have had several Bosch IXOs that have had to be replaced under warrenty because when used for heavier work the trigger welds itself on and you cant turn them off. The battery charging cradle will only accept the tool without anything attached to the tool and is very touchy for connection to charge. Not recommended - not well designed.
Love my 12v DeWalt and the LED light.  The light is a torch that allows me to see clear across a crawl space.  Both are small and lightweight.
  It wouldn't surprise me that when the physical size gets really small that the power will suffer regardless of brand. What are you planning to drive?
  Dose it need to fit in a small space .... tool pouch or something?
