C Ccsgrp Member Joined Mar 10, 2013 Messages 1 Sep 1, 2013 #1 i am new to this and am in the process of refinishing a dining room table. I have a white oak table that I have stripped, sanded and stained. Can I use surfix instead of polyurethane to finish and if so which one should I use.
tjbnwi Member Joined May 12, 2008 Messages 7,381 Sep 1, 2013 #2 I have not used Surfix over a stain yet. I believe the Festool recommendation is over bare wood. Use the heavy duty. Tom
Z zapdafish Member Joined Apr 2, 2010 Messages 576 Sep 1, 2013 #3 I'd use the indoor heavy one I have tested both indoor versions side by side and can't tell the difference
tjbnwi Member Joined May 12, 2008 Messages 7,381 Sep 1, 2013 #4 The One Step contains wax, the Heavy Duty does not. Tom
N nehardwoodfloors Member Joined Sep 8, 2010 Messages 296 Sep 1, 2013 #5 I have used hwo quite a bit on floors. As long as the stain is dry, your good to go!
