FestitaMakool
I drive Land Rover and Mini, sooo.. I will probably not say anything about fast cornering and uneven “roads”
- with my trailers following behind
Coen said:You can make the MFT height with a SYS(-TL) 2 + the equivalent of 7 Sys1's. That ends up being 899.5mm (the MFT being 900) == the same. Those 7 Sys1's can be anything from actually 7x1, or a 5 + 4. Or 2+2+5 or ....
But with the new system you can never get as close to 900 as the old system.
Closest I can come up with is a set of 3 Systainer3's then you get to 897mm;
eg; 137+337+437. Replace '7' with '0', add it all up and add one set of feet (7mm); 130+330+430+7=897
This means the choice of Systainers is way more restrictive. You can only use 3, and those three must add up. You cannot replace one big Systainer for two smaller ones.
You can however use different combos. Eg 137+337+437 or 237+237+437 or 237+337+337
edwarmr said:Coen said:You can make the MFT height with a SYS(-TL) 2 + the equivalent of 7 Sys1's. That ends up being 899.5mm (the MFT being 900) == the same. Those 7 Sys1's can be anything from actually 7x1, or a 5 + 4. Or 2+2+5 or ....
I think I found a combo that works with the new Systainers:
Systainer³ SYS3 M 337 (337-7)=330
Systainer³ SYS3 M 137 (137-7)=130
Systainer³ SYS3 M 112 Feet Included
Systainer³ Organizer SYS3 ORG M 89 (89-7)=82
Total=900
Given that the heights are completely incompatible... I suspect the latter should be read as past tense, that ship seems to have sailed. *sigh*FestitaMakool said:[member=22067]mrB[/member]
I really see the point of racking compatibility, but (FT!) don’t forget the original system.
The T-Loc was designed as a direct "version 2/tuning" of the concept and so mostly displaced the Classic. But still the Classic line SKUs which did not get a functional replacement do soldier on till today like the SYS-SORTs.Gregor said:Given that the heights are completely incompatible... I suspect the latter should be read as past tense, that ship seems to have sailed. *sigh*
mrB said:It’s not even the fact that the heights are different, it’s that they’re not even system compatible with them selves like the original T-Locs are.
The height of my work tops in the photo above is 2x SYS4. But this height can also be achieved with combo of Sys. . .
4+4
4+2+2
4+3+1
2+2+2+2
3+2+2+1
3+3+1+1
3+3+3
1+1+1+1+1+1
3+1+1+1+1
It barely matters what tools I bring to the job, I’ll have some good options for worktop height. It’s so good as a system but they ruined it!
Over time tools and systainers will break, and newcomers will have new style Sys3, and this system will be lost. . Why? Because of some racking system no one ever heard of?
I know I’ve been criticised here before for blowing it out of proportion, and I admit it’s not the end of the world. . . But it sure feels like a massive waste of a great thing.
mrB said:BOTT never sold Systainers before, and don’t seem to currently sell the Systainer racking the Sys3 was designed for (from my half arsed investigation).
Spandex said:If you have a large number of systainers then it’s also presumably possible to swap any new Sys3s that you get for systainers that never leave the home/workshop. That allows you to ensure that systainer stacks used on jobs (where the heights may be an issue) are all old t-locs.
Cheese said:mrB said:BOTT never sold Systainers before, and don’t seem to currently sell the Systainer racking the Sys3 was designed for (from my half arsed investigation).
The racking is Bott Vario 3. This is the best shot I could find on how the Systainers fit into the racking.
FestitaMakool said:Ive noticed also, and cannot see any real reason to change sizes, the shelves would be easy to adapt to existing systainers. Except if FT wasn’t happy with some of the sizes from what they tried to fit inside..
