Cheese
Cochese said:Not the attic floor. That’s 3/4” osb sheets. I went with this because I wanted a plank-look floor, but with a bit more utility and a lower cost.
Ok...now I got it [embarassed] [doh]
Cochese said:As much as I like my task light I won, I need permanent lighting. Went with 40w 5000K 4000lm lights off Amazon. Going to add one or two more banks when the ceiling goes in.
RKA said:[member=44099]Cheese[/member]
I only have experience with sub-$40 twin lamp 4 ft fixtures, but the conventional T8 fixtures never seem as bright as the lumen ratings might suggest. And that's on day 1, the decay on fluorescents really kills their output over time. The HO (high output) fluorescents are considerable brighter initially, but suffer the same decay. I have a pair of 6 bulb T8 fluorescents in my garage that must have less than 5000 hours on them. These were Sylvania 5K tubes purchased. I would ballpark the light drop from new around 30-50%, it's that significant. In cold weather it's worse initially as the tubes need 5-10 mins to warm up before reaching full brightness.
Sam's club sells some Lights on America LED's which I've been using (about $30 ea.), which I love and would recommend (been using them for a year). If you have a low ceiling, don't commit to placement until you can experiment with spacing. The light throw is much more directional than a fluorescent. But the light that reaches your work surface is significantly brighter than the non-HO T8's right out of the box. Now that LED prices have come down, I won't be buying any more fluorescent fixtures.
Cheese said:Looking good...impressed with the amount of light and the spread of the light from those LED's.
Just a thought...would substituting a paper element for the bag on the DC unit give you the headroom you need?
