tjbnwi
- May 12, 2008
Paul G said:fshanno said:Here's what the Tool Snob guy faced.
and as you cut further into the work piece it may ride up like this.
[attachimg=2]
and it may hang in transition.
But this particular problem will be overcome in short order with some sort of wedge attached to the standard base. It's no big deal.
I think the bigger question is how well does this unconventional bevel base work in the middle of flat material for more routine bevel cuts. Is it stable? Is half a foot enough for reliably stable cutting from above and below.
If I get a Carvex I will be using it to do traditional jigsaw stuff and much more. I intend to effectively replace my conventional circular saw with a Carvex. That's right, replace. Completely replace. As in never use again. At $350 (or $550 for the battery unit) it's got to do that for me. Cause I'm poor but I like nice tools, I like Festool and I need a jigsaw.
Tom's post #57 is addressing this directly, instead of the angle plate being being adjusted concave, make it convex and support from the other side.
EDIT: unfortunately that won't work though if there isn't enough material to support that side of the plate, as in scribing a cabinet
As long as one of the wings can be placed on a face frame/filler it is wide enough. The most common "factory" face frame is 1 1/2" with 1/4" scribe projection. No matter what/which jig saw it is, the base does not have full purchase. I use an old Bosch 4200, one that you need the long screw driver to change the blade. The base is 2 1/2" wide, there is no way on an 1 1/2" face frame I'm going to get full plate contact, with or without a bevel.
Again, I have no clue what or how this is an issue. As I said the rest of the world has not had a problem with this in how many years? Guess they're just smarter than the tool.
