Ken Nagrod
Who told you to go riding your bike? You should be in your garage using your Festools. [poke]
Kodi Crescent said:I was riding my bike this afternoon, and most picket-type fences were in contact with the ground. But most of them weren't stained, and they were probably built using arsenic treated wood.
jmbfestool said:WarnerConstCo. said:At least he showed up to try and fix it, albeit on a Sunday.
The strip of ply works as a good smooth guide on the ground to ride the saw on.
I think the offset on most sidewinders is an 1 1/2". Poor ryobi saw.
It is a lot of work to keep a consistent gap when the ground pitches and rolls alot.
Ply is not flexible enough unless its flexi ply. That's y I said hard board as it's flexible enough but also very smooth on 1 side so the saw will easily glide along the smooth surface.
Jmb
Brice Burrell said:Kodi Crescent said:I was riding my bike this afternoon, and most picket-type fences were in contact with the ground. But most of them weren't stained, and they were probably built using arsenic treated wood.
That's because it's easier to just set the fence panel on the ground to install it. You'll get that with the low bid every time. Glad to see that it seems to be worked out.
awdriven said:4 years within about 1.5 inches from the ground and my cedar fence is doing OK. PVC just seemed soulless and clinical. If you ever have to replace parts, you also have to sweat it out and hope you can find a source for compatible parts.
Kodi Crescent said:How about this for a crazy scribing idea? Get a lawnmower wheel with the desired diameter from one of the box stores, stick a pencil through the hub, and roll that alongside the ground? Maybe put down the Masonite first to even out some of the peaks and valleys. Any thoughts on this?
Jay Knoll said:Ummmmmmmmmmmmm you know the old saying, "If all you've got is a hammer, every problem looks like a nail? I know this is a FT forum but it seems to me that a shovel would be the proper tool, dig a little under each slat to acheive the desired clearance. And you don't have to worry about GFI failures.
Just a thought
Jay
Ken Nagrod said:Wallpaper hides everything. [big grin]
