tjbnwi said:Would it be faster, easier, simpler to remove the module to set the bevel angle than it is to try and adjust the angle from an awkward position? There module if I recall correctly is held in by a couple of Zuess fasteners.
Kev said:tjbnwi said:Would it be faster, easier, simpler to remove the module to set the bevel angle than it is to try and adjust the angle from an awkward position? There module if I recall correctly is held in by a couple of Zuess fasteners.
I suggest you get back to those limbo dancing classes [big grin]
That and the speed control, etc are the very reasons I'm still on the fence between a CS70 and a TS75+CMS.
Stone Message said:tjbnwi said:Would it be faster, easier, simpler to remove the module to set the bevel angle than it is to try and adjust the angle from an awkward position? There module if I recall correctly is held in by a couple of Zuess fasteners.
Hi Tom
You are on the right track - the CMS Support Module (the thing the saw is fixed to) is held in by two screws that are turned through 180 degrees to lock or unlock it from the CMS Base Unit. If precise angle adjustment is needed and you are not a limbo dancer then just undo the two screws, swing the saw up, adjust the angle and then lock it back - probably less than 15 seconds. I edited out (I think) the bit where I said that I probably only do a couple of angle cuts a year on a table saw - most of my angled cuts are done with the saw on a guide rail and that is really easy.
Stone Message said:Hi Kev
A good question...I used the TS55R, on its own, to do about 90 feet of 30 degree cuts along some plywood sheets and some 2x2. The cuts were done at different times and the saw was set back to 0 degrees between cuts. All of the cuts were spot on.
In my tests of the TS55R in the CMS Unit I took the saw out and put it back in many times. For the first 6 or so times I checked that at 0 degrees the blade was square to the table. It was spot on every time and so I stopped checking. So, given that the saw is perfect when doing angled cuts when used on the tracks and that it is square to the table when in the CMS Unit then I feel safe assuming that the inclination measurement when in the CMS Unit will be spot on as well.
As I said, I know that it is awkward to set the angle with it under the table but it only takes seconds to undo the two screws and flip the CMS Support unit over if it helps.
I managed to see the CMS-TS55R demonstrated at a show (forgotten which one now - that must be an age thing I suppose). Why not see if your dealer has one to demonstrate.
Kev said:Stone Message said:Hi Kev
Thanks Peter,
The guys at my local will probably be happy to toss a saw in a module for me [wink]
Based on what you're saying and the fact that it's an accurately calibrated saw against a flat panel ... all would probably be cool.
Kev
The maximum depth of cut at 90 degrees is 51mm. I used to have a big table saw which could cut much deeper but I now prefer to do cuts over 51mm on my bandsaw. I have found that it cuts faster than a table saw and do not mind having to put stock through the thicknesser afterwards.Acrobat said:Peter, I didn't hear or see any mention of what the maximum height left is when the saw is in the module?
I have an old triton workbench years old now that predates this setup, but it came with a large saw and even that I've found doesn't go high enough when I need to cut thick timber because of the table thickness taking up a few precious mm's. If it's for the ts55 saw how deep can it cut when in the table?
thanks
